Cumulonimbus
- 12 000 feet up
2008 GTI with APR Stage 1 FSI
My OEM DV finally blew up the other day giving me 0 boost but no CEL.
I purchased the Rev D DV off ECS, the after market OEM unit (perhaps a bad idea).
After installing I have an issue which usually happens while the car is cold, or warming up.
The car will not go past about 2-3psi when the car is first run after it has cooled down (but is back up to operating temp). This lasts untill the throttle is tapped a few times (boost to vac), or you hold your foot down through the boost resistance, and it will slowly climb to 10ish psi. At that time if you lift off then give WOT again, you get full boost - or a massive spike to around 28psi once, and after that all is normal. The normal boost usually lasts the remainder of the drive until the car cools down.
Is the DV defective, or do I have a problem elsewhere?
I am spiking 22ish psi and holding around 17 psi, tapering to around 11 at redline.
