Dredknut
DSG Fart Fanatic
- Its not important...
- 2007 GTI
I recently had the recall done for my coilpacks, all 4 were replaced under warranty.
Since then I have been experiencing what I think are misfires under certain conditions... Basically, when I am WOT in 4th gear or higher, 4k+ RPM I get hesitation from the engine and a blinking check engine light. When I let off the gas or just give it partial cruising throttle, the misfires stop and the check engine light disappears. This has happened on 2 occasions, and then finally today I have a solid check engine light.
Power delivery is normal in the lower gears at high rpm, the car still pulls well. I have no cold start issues, and I have replaced my cam follower within the last 15k kms with 2 oil changes since then and regular top ups. I don't have access to a vagcom, so I can't confirm the hesitation I am experiencing is infact misfires and not fuel cuts, etc.
I am convinced its faulty coilpack(s) that were installed, but I am also skeptical that it could be my plugs as well. I have an apt with the dealer next week, but I am curious if there are any other possibilities I should be considering? Am I on the right track?
Mods are as follows:
- APR Stage 1
- P-Flo with dryflo
- BSH DV
- BSH Stg 1 PCV
- NGK BKR6E plugs
- APR Stage 1
- P-Flo with dryflo
- BSH DV
- BSH Stg 1 PCV
- NGK BKR6E plugs
