VictorHuge
- Toronto
Hi folks, been getting a few codes lately along with occasional epc light and based on those i figured worn pcv, injectors, spark plugs and maybe map sensor; coils would be next on the list if that didn’t work. Took off the intake yesterday to change parts out and found cylinder 3 intake to be very oily. I would think the oil suggests the valve seals are going? The car has been burning oil unfortunately and this kinda explains it i guess. I suppose my question is, would a misfire or stuck injector cause oil consumption, or am i right in thinking it’s the valve seals? Added photos of cylinder 1 and 3. Unfortunately all of them are growing a carbon fungus.
I did want to mention the intake removal was made unnecessarily difficult by the fact top outer bolts on the manifold are studs and not bolts. If yours has bolts, make sure you have a stubby offset 17mm to reach the fuel line as you cannot pull the intake off otherwise.
Trouble codes below:
P130A00 - Hide cylinder Intermittent
P03AF00 - Cylinder 3 Pressure Too High static
P006800 - MAP/MAF - Throttle Position Correlation Intermittent
P227900 - Intake Air System Leak Intermittent
