HACBassoon
- Lakeland, FL
How many are there and in which wheel wells. Hoping to get it done this weekend, these headlights are dangerous
yeah this is the thing.. EVEN if your hid levelers are in the correct positions, your HIDs will still be low because of the drop of the car... people are saying "its fine after you fix the position of the levelers" but i don tunderstand how people can deal with the lack of visibility from the lower headlights.
sorry im a noob
so if you can manually adjust the headlights like this, why do you need the vagcom?
You just want to have Vag-Com make sure that your sensors are working correctly, and isn't damaged. The values that you check on Vag-com are working ranges for the HID LEVELERS them selves. You manually adjust them, but want to stay within these values for the HID to adjust properly, if you carry a heavy load you want your headlights to adjust for this, so if they aren't the acceptable range, then your lights won't adjust correctly.
This is my understanding. I checked with vag-com after my spring install and my values were in the acceptable range. Then i manually adjusted them against a wall 25ft back. Now they are perfect.!!
i got the prokits too... so i was wondering, any chance you remember how many times you turned the adjusting screw for both headlights? =/
because i dont hav ea clue what to adjust the lights to, i dont want to make them too high and blind people
