BartekPL219
- Chicago Suburbs (near O'Hare), IL
Hi all,
Just last week I had replaced my valve cover gasket because I had a suspicion that it was leaking. That install went fine. During that install, I took off the pcv plate (I have the BSH street catch can setup) to also replace that pcv gasket ( the one with the 2 circles and 2 squares). And now, the pcv plate won't sit flush against the valve cover; where before it was. Car is running fine, a little sluggish but fine; alothough it's leaking air because I can feel it upon hitting boost. Here's a pic:
This is really aggravating; and I hate driving the car knowing something is not perfect. I tried tightening the screws as tight as possible, to the point of even stripping screw, and nothing. I retapped the stripped hole with a bigger thread and put a bigger screw in and still nothing.
What can I do?? I found a new valve cover on 1stvwparts for $180. Will a new valve cover fix this? Because I'm really concerned that what if I buy a new valve cover and it still won't sit flush?? Help!
