Help!! having some major issues
limdoo12
Alberta, Canada
so i was on my way home coming down the highway (5 hour drive) when i hit a small bump, i heard something fall off my car but i didn't pay much attention to it until i came to a stop. when i pressed in the clutch it felt a bit grindy, not the smooth feel it normally had, when i let it out to switch from 1st to 2nd it really jolted the car, not something i've ever experienced before. also when i let off the gas and went back on the gas it would also jolt. there was also vibration i could feel through my foot pedals. but i needed to get home as i was driving on the highway through bc back to alberta. after i was about 15 minutes outside of my home town something really weird happened after i came to a stop. An exhaust gasket started leaking, and about 5 minutes later my power steering light came on and i had no power steering!
does anyone have any insight as to what this could be caused from? i'm hoping i don't have a serious problem with the engine or transmission. do you think this could be from an engine mount going on me? or the dogbone mount? i just dont understand how the clutch steamed all of these issues. especially the power steering.
nkresho
suck, squish, bang, blow
Pittsburgh
2022 Q3
if a mount went, your engine could be leaning up against something, giving you that pedal feel. I know an intake resting against the brake fluid res feels funny in the brake pedal. Based on symptoms, I'd say dogbone maybe. Mine was sheared off by a manhole cover when they were paving my street. It went all the way and the engine torque took out one of my a/c lines when the serp belt rubbed it.
Definitely don't drive it, until you find the issue.
limdoo12
Alberta, Canada
Thanks for the reply I'm going to check the dog bone once I get a chance to go back home I just don't understand how all of these problems could've stemed from that
firas1981
lebanon
its your mounts. check all your mounts ( engine transmission and mostly dogbone issue )
your problem is there and re check your subframe after issue solved for re tightening and adjusting.
