Chumeta
- Vitoria-España
Hi, my heated rear window is not working. The switch turns on, the electrical relay is heard, there is no fault in vcds, which may fail. Does anyone have an electrical scheme? Thanks
GTI's nailed it... that is a common known problem with GTI Mark V's, though. None the less, thanks for at least following up with confirmation of your problem. Too many people post problems and then never follow up.Thanks for your help. I have already fixed the problem, the wires cut inside the rubber tube that joins the bodywork to the tailgate on the driver's side. I show you photo
