Mostly finished rewiring my car to remove leads for all the stuff I'd taken out, also relocated ECU to the interior. Ended up with about 15 lbs of wire. Went for a test drive today and noticed that when I let off the gas, the car would engine brake immediately and with force. To clarify,
-Car rolls freely, nothing is stuck and the brakes & e-brake work normally
-Rear O2 is disconnected pending extension of those wires to the ECU
-F2 & F3 (marked as ABS in the manual) as well as the fuses marked for audio were removed
I'm guessing one of the fuses or the disconnected rear O2 may have disabled the catalyst heat rev hang and this is responsible for the much more immediate engine braking. So, my question to people who have had the eco rev-hang deleted: does your car engine brake much more immediately and aggressively?
