OP, what's the speed rating of your tires? The top speed of a stock car never exceeds the capability of the OEM tires. I'm guessing they're H-rated.
R's are Y-rated to 168 MPH, overkill without a tune.
And pointless even on a track- more relevant to the autobahn in Germany.
Yes, my stock tires were Continental ProContact H rated (130mph). The speed rating is there to let you know that you shouldn't exceed that speed with that tire. If you do for a SUSTAINED period of time the air in the tire will heat up and expand causing the tire to explode.
“Speed ratings are certified maximum sustained speed designations assigned to passenger car radials and high performance tires. Because of the evolution of high-speed passenger car travel, it was necessary to establish a way to rate a tire's high-speed capability. In the U.S., these ratings are based on tire testing in laboratory conditions under simulated loads (European testing uses actual road testing). For a tire to be speed rated by the U.S. Government, it must meet certain minimum standards for reaching and sustaining that specified speed.”
Source :
https://www.yokohamatire.com/utspeed.asp
“Speed ratings in the US are based on laboratory tests where the tire is pressed against a large diameter metal drum to reflect its appropriate load, and run at ever increasing speeds (in 6.2 mph steps in 10 minute increments) until the tire's required speed has been met.”
Source :
http://www.tirerack.com/tires/tiretech/techpage.jsp?techid=35
According to converations I've had with tire manufacturers, they are under-rated to protect themselves. It's a liability rating. As the medical profession calls it CYA: Cover your Axx. More air pressure+heat+centrifugal force is a bad combination. Even if they survive @ 150mph with the 130mph rated tires, it would be easier to blow-out from pot-hole, road obstacle, etc due to all the force to the walls and contact area of the tire.
Like I said, it DID take a little bit to get to 125.
Albeit not 10 minutes, but it sure seemed that way when it happened!
