I know these turbos eat oil but this is A LOT. How much is an upgraded PCV kit and installation fees?
The most basic PCV modification is called a "block off plate" or "revamp" for about $100. Basically the front PCV inlet on the manifold is disconnected and capped off, the unreliable factory PCV valve is eliminated, and all the PCV gases are plumbed out the valve cover's rear PCV port to the intake, where it then goes through the turbo, intercooler and all boost piping before being burnt up by the engine. Another modification is to buy a catch can kit, either recirculating or VTA (vent-to-atmosphere aka race) setups. Be careful with these if you live in a cold climate.
Exhaust-routed PCV setups are custom. A port nipple has to be welded into the downpipe after the catalytic converter. PCV gases are ran out the valve cover's rear port straight to the exhaust. A venturi effect creates slight vacuum on the crankcase, which is ideal. Total cost is about $225.
I recommend a 5-40 oil from a European company. The US has regulations that allow oils to be called "full synthetic" that would not be considered full synthetic in Europe. Liqui-moly, Pentosin, Eneos, Total, Vaico and even ester-alcohol based oils from Motul and Redline are all great. You can buy these online for cheaper than you pay for Castrol at the local auto part store.
