every turbo has some sort of dump valve / wastegate, it prevents the turbo from spinning backwards when the manifold stops the turbine from going forwards (i.e take ur foot off)
i just want an upgraded one
you'd be better off with an upgraded diverter valve rather then a dump V.
Found in the same place and very similar but the diverter valve retains the boosted air by dumping it in the intake, rather then loosing it like the dump valve does. Plus this way you keep the turbo spool happy and you dont sound like the local scooby driver from the estate lol
Possibly look into an EGR valve and a replacement intake system if you want a nice induction sound :thumbup:
lol oh fellow gt tdi owner wanting a dump valve...lol
iv had many a conversation with many a ppl regarding fitting one and getting one.. iv been in touch with companies galore.. but apart from the general answer of NO DONT DO IT.. you actualy cant, cause they dont make them for diesels anymore...
ouch.....£295. i bought a forge split-r for my mk4 1.8t GTI and that was only £110
None of the 2.0 diesels come with a dump valve/diverter valve.
If you got a re-circ type dump valve they it'd not give hinm the desired "dumping" noise - atmospheric would give a better audible noise.
The re-circ valve wouldn't make that much difference as the cars aren't designed to run with one anyway.
Diesels run very small turbo's so spool quickly - no real advantage is to be had.
Wrong ! :eyebulge:
Look here :
http://www.zen19051.zen.co.uk/prod01.htm
They can provide you with one - personaly they're not to my taste, but whatever puts a chubby in ya pants :bellyroll:
HIH
Tom
I was re-fering more to known companies.. ie - Forge..
