Fuel Cut Causes
Stranded in Daytona
Wilmington, NC
06 2 door TR GTI
I'm trying to narrow my list down on possible causes of fuel cuts.
I have installed the updated LPFP.
I checked my Low Pressure Fuel Sensor and it appears to be an older version, as does my LPFP wiring harness.
Should I replace these two things next? Or is there something else I should look at?
Just had my Cam Follower replaced and it looked good... cam lobe had minor scoring to it, but nothing horrible.
gbkoen01
Louisville, KY
Mkv gti
Tuned? It's more than likely the hpfp.
avenali312
Mableton, GA
2015 GTI
Is your LPFP control module still in its stock location under the rear seat? Has it been hot lately and you've taken long drives? Mine tended to overheat in those situations and cause cuts until I put Eric's extension harness on and relocate it under the passenger seat.
