bigdyno
FIA World Rally Car Newbie
- Toronto, Ontario
I had indicated that I was having front end noise in a previous thread and thought it might be the fuel line problem that some others on this thread were experiencing. When I took the car to a dealer, they discovered it was sub frame bolts that had loosened off, so they retightened them and all seemed to be corrected.
Not so. I was changing my oil a week and a half ago, only to find these bolts were loose again. The car went back to the dealer and this is the story, it sounds reasonable, but I am skeptical about anything a dealer tells me.
The bolts are torque to yield, which means that the bolt is engineered to stretch a specific ammount and maintain a set tension when torqued to spec. Once the bolt is loosened, it is junk as it has been stretched. The bolts pictured are all torque to yield and needed to be replaced.
My concern is that the new ones have all been installed with an impact, not a torque wrench,(you can tell by the markings on one edge of the bolt heads) so I may experience this all over again, but lets hope not, eh.
Here are some pics of the bolts as I found them, when I get a chance I will take a few of how they are now that they have been replaced.
Also note all the paint they scraped off the sway bar, I had them touch that up as well......
