Mark7GTi-sport
- New York
Not true, there's a local shop around my way that has injectors available for this setupSo the injectors flow a bit more fuel. If you are running a L450 or EQT Vortex sized turbo this might allow you to run 28-29psi out to redline on pump gas vs having to taper it without the extra fueling.
The euro manifold + injectors are missing the wiring harness so you would need to purchase that. Also, OEM injector connectors are different than aftermarket Bosch so you have to get harnesses for those too.
Installing the manifold and injectors as it comes from Europe is a waste of time and makes it harder to upgrade those items at a later date.
