i own a 2007 gti , 2.0L FSI with 60000km, it has a few modifications but its stock ecu at the moment, it has a dsg gearbox, and has changed issues with gear changes.
at low revs and high load the car jerks forward, loses power , then regains power and does this again for the next gear change,
the issue is more pronounced if i alter my stance on the accelerator, and at times the whole car has nearly cut out because of the sudden erratic gear change.
the code reads ;
SCAN ENGINE AND TRANSMISSION CONTROL UNITS
***FAULT CODE NO. 49409/NO COMMUNICATIONS WITH TRANSMISSION
CONTROL UNIT/008 IMPLAUSIBLE SIGNAL
CLEAR CODE
so any ideas what causes this error ,
car is booked in to vw for nxt tuesday so ill let you know if no one posts it here.
the code reads ;
CLEAR CODE
