Hi hoping some one can help me with a fault on my 2007 ed 30, noticed a slight miss on tick over when I stop at junctions and lights, and a hissing sound on engine switch off,
Closer investigation I could see the pcv was sucking in air from a small factory hole on the saucer part, took it off and seams to work fine you can suck one way but not the other, ordered a new one and fitted it just to be on the safe side,
With the new one fitted the engine revs and hunts between 1000rpm and 1500rpm, it pulses continually, I have changed all the spark plugs and new air filter and cam follower and dv, notice if I open the oil filler cap slightly to cause a vacuum leak it ticks over normally, hope some one can help it is driving me crazy,
Codes from vcds
Friday, 30, October, 2015, 14:53:44:21178
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 15.7.1.0 (x64)
Data version: 20150904
www.Ross-Tech.com
VIN: WVWZZZ1KZ8W016680 License Plate: MARC ED 30
Mileage: 84980km-52804mi Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72
VIN: WVWZZZ1KZ8W016680 Mileage: 84980km-52804miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine Labels: 06F-907-115-AXX.lbl
Part No SW: 1K0 907 115 T HW: 8P0 907 115 B
Component: 2.0l R4/4V TFSI 0010
Revision: 5BH16--- Serial number: VWX7Z0G43NE91R
Coding: 0403000318070060
Shop #: WSC 79925 024 394855
VCID: 3778A67A461F3E86AC-8062
1 Fault Found:
004243 - Bank 1; Fuel Measuring System 2
P1093 - 008 - Malfunction - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 2
Fault Frequency: 5
Reset counter: 255
Mileage: 81519 km
Time Indication: 0
Date: 2000.00.00
Time: 08:59:30
Freeze Frame:
RPM: 1636 /min
Load: 17.6 %
Speed: 29.0 km/h
Temperature: 27.0°C
Temperature: 9.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 14.605 V
Readiness: 0000 0000
Codes from vcds
www.Ross-Tech.com
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 5
Reset counter: 255
Mileage: 81519 km
Time Indication: 0
Date: 2000.00.00
Time: 08:59:30
Freeze Frame:
RPM: 1636 /min
Load: 17.6 %
Speed: 29.0 km/h
Temperature: 27.0°C
Temperature: 9.0°C
Voltage: 14.605 V
