Early in the morning...
blkmaggtsp74
Sweden
I installed some 20mm spacers all around with my Classics. Bringing it down to et34. I think it looks a hell of a lot better.
Just some quick iphone pics with too much sun in my eyes but anyway...
Getting tired of the black and blue on the wheels so there will be some painting this winter.
blkmaggtsp74
Sweden
Adding some better pictures. Been told i shouldn´t go with more than 10 in the front and 15 in the back. But i really think this looks way better and havn´t had any problems with rubbing.
akaprince
brooklyn, ny
2008 GTI BMP 2DR DSG
needs more low.
josein06gli
GLI OWNER
San Diego, Ca
VW Jetta GLI
If ur rubbing in front do the fender screw mod, look it up.
Dredknut
DSG Fart Fanatic
Its not important...
2007 GTI
Just keep in mind the wider you go the more stress it puts on your wheel bearings. 20mm is pretty thick, so it just means you may end up replacing worn wheel bearings sooner than you would running 10 or 15mm spacers.
Btw, looks sweet :thumbsup:
Bowie MD
08 UG GTi
Yea but that would be the same stress if you added wider wheels with lower ET, right?
No. Its because the spacer is making everything from the lug nuts to the bearing work harder. A wider wheel wouldnt make this happen.
