Dumb Question
bayarea7
Bay Area
'15 RSM 2 door S 6M
So who pre mixes G13 in a separate container than adds it to the reservoir VS just adding equal parts distilled water and G13 directly into the reservoir?
johnnloki
Bowmanville ON
(puts up hand)
But don't let that dissuade you. It's probably still a good idea.
bayarea7
Bay Area
'15 RSM 2 door S 6M
Im good at eyeballing, so I go water then coolant. But thats cause I know how much. You can eff it up if you put too much of either then when you pour the other and there's no more room-- so you just fucked up the dilution. For those people, I recommend pre mixing lol
DAS_STIG
Chicago
Is it really important to get exactly 50/50?seems like a bit extra either way wont do much harm - one way a bit extra cooling, other way a bit lower extreme temp viability. Unless you are in crazy cold -40 temps or seriously romping it on track wont make much difference.
mk7_bk
From what I read, if ur only a little bit low add some distilled water. If ur a lot low use G13 make sure u 50/50 mix it as its concentrate. If ur like me, I added some sh*t from autozone that they said would work. Couple splashes. Car hasnt blow up yet.
johnnloki
Bowmanville ON
Legend has said for years that non g13 pink stuff coagulates and basically turns to jəllö when mixed with g13.
I've read about that for 14 years or so.
Haven't heard of anyone actually experiencing those consequences.
Sent from my SM-G965W using Tapatalk
mk7_bk
Ya on the other thread I got some replies that I should flush or I might be ok. I do know what your taking about tho, makes the bubble look brown lol
bayarea7
Bay Area
'15 RSM 2 door S 6M
Unless as mentioned above, if youre in harshly cold temps or a track monster (neither apply to me) you'll be fine eyeballing. Im OCD and had to use oem g13 only. I was lucky my dealer had it on hand for even cheaper than what I could get it for online surprisingly. And if you're a tad low, topping with distilled water is fine. At one point, the light came on and I was alarmingly low, reservoir turned out to be almost empty! I was sure I had a leak somewhere, but no evidence in and around the system. refilled with 50/50, after a few drive cycles, nothing. *shrugs* Weird.
