Tiny turbine. Did u wiggle the turbine shaft to check for play? I'm sure it LOOKS like that at 60k or 160k miles. There is nothing out the ordinary unless I'm misiing something
I moved it with my finger and it spined fine, never seen or touched it before so I have no idea if my turbo is good or bad its still stock turbo and lately I feel the car has loost boost but I have no boost leaks:/
How would I know if its going bad? I haven't even gone stage two I've been broke lol might just got ko4 when the turbo goes out. But I've wanted to move up one state at a time
i believe that a ko3, since it is a journal bearing turbo and not a ball bearing turbo, there will always be a small amount of side to side play. its the endplay you need to worry about, not sure what the exact tolerances are, but if you search the interwebs you will find lots of info about ko3's (any b5s4 forum)...did you notice smoke when under acceleration or above average oil consumption recently?
Well I just checked my oil today and it seemed to get about halfway pretty quick in about a month and a half or so, and I get some black smoke at wot
But not much, could it be the piston rings wearing out causing my oil consumption?
possibly, but normally the seals of these journal bearing turbos would last much less longer than piston rings...also a turbo will eat oil much faster than worn rings. So it if it is your rings you are in big trouble...if the turbo is out of the car then swap in a new ko4 or if needs be another ko3
