vwengineer
- Switzerland
What?!?plastic on CF to hide issues enough to sell car.
An extra end cap?
The oil pickup has a grill, normally it should not allow metal parts to go through and the microscopic ones should be filtered out by the oil filter (of course it will not prevent immediate damage)
What?!?
At this point just put a new CF in and check it periodically until you saved enough money so you can do the job correctly with new parts and not used.....
Op you should a last drop oil pan clean it out and place magnets on oil pickup to catch the metal shaving, this is what VW does when doing this type of repair.
yea the whole complete stock internals that i pulled when I did autotech internals
I know that, that's why I said it would not prevent immediate damage. My reasoning was that since the cam follower was already eaten through and the car was driven like this, most of the metal particles in suspension where already filtered, but yes a magnet cannot hurt.I am not sure if you realize that the oil that goes into the pickup trough the oil pump is not filtered 100% by the filter, some of the oil is bypassed and does not get filtered but is sent through the engine anyways.
I, personally, would not buy a used cam...here again spending $200 to avoid or prolong spending another $550 is another $200 spent on doing it correctly and avoiding further disaster. But you seem to be determined to avoid spending what you need to to do things in a safe and permanent manner, which is confusing when you look at your viewpoint on the end cap vs just a CF. I ask myself "why do a new end cap rather than just a CF and then do all the work adding a used intake cam rather than a new one?" Seems you don't mind doing more than you need to in order to save a few bucks now but end up spending more in the long run so you can attend to scheduled periodicals that may not even be in need of service at this time. I'm more a once and done thinker I guess and would address top priority needs first.
Yeah, I get it. You do what you have to and can given what you know to need being done. Only you can best determine how to go about it. I do have other cars and would sideline the MK5 doing things once with new bits...and I hope you can get some relief from repairs. You have the cam chain coming off as well when you do the cam swap...are you planning to add a new chain tensioner or vacuum pump while having it in that condition? Other bits to consider even though you can do so when you readdress the valve job. Four years ago I rebuilt the head, rings, and rod bearings on mine...but I let the cam chain. tensioner, and vac pump go. Now I have oil leaking from the vacuum pump and am looking at doing all these soon. I want to get cam tension data from others soon with a K04 first to compare how far gone my tensioner is.
I might be wrong but I think that removing the vacuum pump is only like removing 4 screws? I also have oil leaking there so I should also have a look.
I've got an oil leak that appears to be coming from around the vacuum pump too. Thanks for cluing me in about the chain. I may change if I can budget it in. What is it driving?
