RCD 510
While this may seem complicated, once you know what you're doing, taking it apart takes 5 minutes.
Remove the one screw at the top. Size 8 torx. There's clips around the outside of the top panel. Pry them open. That's all that holds on the top.
Overview photo:
There's 2 parts to the front, a metal frame and the screen itself.
The 2 yellow screws hold the metal frame. The 2 red screws hold the CD player. Remove them from both sides.
At this point the CD player and metal frame should be free.
I didn't disconnect the CD player. There's not a lot of slack, so I set the top panel off to the side and put the CD player on it. The CD player should simply lift straight up. Make sure it doesn't get snagged on the back.
Now you can undo the red harnesses at the end of the beige wires. I would take them off the board, so you can clearly see what you're doing. Close up of the red harness in the photo below. They simply pry off, no clips. There's an alignment post on one side when you go to reinstall.
The large data ribbon also needs to be disconnected.
The brown lever clips it in place.
Flip it upwards to release the data ribbon.
Now you should be able to separate the metal frame/screen farther from the body of the radio.
Note how the SD reader fits in an opening at the bottom of the radio.
There should be enough slack to lay the screen face down.
Undo all the screws around the face of the screen.
The surface screws hold the metal frame to the screen, and the deeper screws hold the circuit boards. You can undo them all now. Size 7 torx.
Pull off the metal frame, and you'll have access to the 2 circuit boards, one on each side.
You can also detach the SD card reader. There's a clip on each side. Pull them away from the center to release the SD card circuit board.
2 PLCC-2s. I left it attached to the radio itself while I swapped the LEDs.
Make sure all the screws are removed. Gently pry up the circuit boards around the volume/tuning knobs. The knobs should pop off the front, and the boards should come out.
19 plcc-2 LEDs.
Now that the boards are loose, you can also remove the red clips on the other side of the beige wires if you choose.
Reassemble.
Screw the circuit boards back to the screen, the screen to the metal frame, and then join the metal frame to the body of the radio. Be careful with the data ribbons, the large one gets folded to enter the slot on reassembly. The red harnesses can also get in the way. Make sure the SD reader is aligned with the lower opening. Then place the CD player on top.
In order to test the LEDs, I installed it partially reassembled.
I put 2 screws in to hold the CD player, screwed the metal plate to the front, and left the screen off. The circuit boards and SD reader were left loose and hanging out the front of the metal face plate. I plugged it in and turned on the car lights, which should illuminate all LEDs.
