Good DIY I was a little confused at times with the torque suggested for some parts in this but I just cross referenced with the Bentley manual to get the exact specs.
However in my experience this afternoon it took me about 3 hours from start to finish. Now the car has 101k miles on it (6 MN winters of salt and sand), original rotors and bearings. I would doubt it takes that long for many people, probably more like 1.5hrs if you don't run into the problems I did.
The first issue I had was while I was taking the first triple square off. The bolt got partly stripped on one side because I couldnt get the 12mm socket properly seated in the bolt. I was also slowed down because the axle wouldn't come out all the way, leaving little room for gaining access to the triple squares.
Before I got any of these removed my rotor still wouldn't move off the hub (yes the small torx-30 screw was out). I thought it was just rusted on and needed a good hit with the hammer a few times. So I started to see progress with the hammer. Needless to say as soon as it came off, it also took off part of the original housing bearing with it so I could see the actual bearings. The rotor had seized to the outer part of the bearing.
I was able to separate the rotor from the housing by banging it out with a 36mm socket and some wood blocks.
Now back to the triple squares. I was able to get them started after I took out the torch (benzomatic yellow can). I heated up the housing along the triple square bolts and then they slowly started to turn.
Installing the new bearing wasn't too hard. The only issue I ran into that out of the 4 new 12mm triple square bolts, only one fit the triple square socket. I got the ECS complete wheel bearing housing kit. I think it was the zinc coating on the bolts. I simply pounded the socket into the bolts until they seated well. Easy fix but the bolts shouldn't be that cheap (seemed to be made in China based on the box they came in). Still a little disappointed but you get what you pay for. This 2 bearing complete kit was half of what the genuine VW/Audi would have been.
The only issue I ran into there was just trying to move the axle around to get the 4 triple square bolts in. Space was tight.
I would recommend you have a friend help you, especially if you don't have much experience or you run into issues like I did.
When looking at the bearing I saw dirt and other small debris in and around the bearings. Here are some images:
