Raguvian
- Bay Area, CA
- 2019 GSW 4MO 6MT
This is one of the coolest DIY mods IMO. Thanks a ton OP. I have too many other projects to do right now but this is definitely on the list.
I have it working.
I ended up tapping the bracket so I could thread through it instead of epoxying nuts in the back. I'll probably throw some loctite on the bolts just because. I didn't use the aluminum ones, I just used some regular button head 6-32s that I had laying around.
I also never got the nut for the solenoid so I had to cut a nut down to make it fit. That was a pain in the ass.
I tried doing double return springs since with how far the shaft can retract, it seemed like there wouldn't be enough pressure. Turns out there was too much pressure with the double springs and the solenoid couldn't actually get it started. If I tapped it with my finger it was fine. So I removed the second spring and it's been working.
I just have to mount my switch. I did a momentary toggle in the cubby. I'll probably do a button instead.
Thanks for the work figuring this all out. It's a hack and I wish it could be done in software instead, but it's a great solution anyway.
hey fella's tried and failed again. i can get the second item active plunger all out, but cannot get the first control item inactive (plunger de-activated). how did joedubs get the magnet onto the end? epoxy or the rubber thingy like ridbjj? so far a real pain to get this working. ridbjj, definitly matters if i change magnet orientation and then i don't get the active on the plunger depressed but do get the de-activation on the plunger retracted..i tried all types of combinations of magnets and lengths. it's not an easy feat to get this to work.
ok will do. thank you.It sounds like the whole rig is just slightly too close to the sensor. I definitely remember the difference between sensor 2 deactivating or not was miniscule. Can you move the rig back towards to passenger side a bit? Maybe grind the holes in the clutch housing to be a bit oval? 1 or 2mm could be all it takes.
Got a Pic of your setup? How did you end up putting the magnets on the end?
Sounds dumb. I used the cap from a magic marker. It's the right diameter for the magnets to fit inside it. I cut it a shade longer than the magnets themselves and I was able to epoxy it onto the end of the shaft. I wasn't crazy about that because now I can't remove the shaft.
It allows the shaft to retract far enough to deactivate everything. It actually retracts a hair TOO far. I need to throw a washer of some sort on it... Its so far back that it doesn't always trigger. Works 99% of the time. I've had one failure and it's when the car had been sitting in the sun for a while. All I had to do was tap the back and it worked fine again.
I thought I took some pics but I can't find em. I'll try to snap some later.
Thanks. shortening the spring and adjusting the magnets just a bit did the trick!. finally got to work on it and got it working!! thanks much!!!..Right, any magnetic influence when it's retracted could prevent it from extending.
But you could Try a different shorter spring, or yes cut it down a bit.
Also, dab a bit of grease at the base of the ro
Seems like you've almost got it.
C10BF01 - Clutch position sensor Electrical error
Intermittent
C10BF29 - Clutch position sensor Implausible signal
Intermittent
Ridebjj
So after all these months, when you scan, do you see these at all?
Code:C10BF01 - Clutch position sensor Electrical error Intermittent C10BF29 - Clutch position sensor Implausible signal Intermittent
Edit: another question.
This is what the bracket looks like after uploading to shapeways (using .stl format)
Seems incorrect. Ideas?
Sent you a pmNope. I haven't had those codes.
Somewhere in this thread there's another link to the corrected file.
On page 5 you said you updated your shapeways link with the new file.Yea, another user contacted me by Dm and said they told him the same thing. Which is weird. Mine went through no problem. But I got the new version of the fixed file they sent him and updated my shapeways link with it.
Sorry about that.
I'm going to try and get the diy up this weekend.
