Mini7
- Charlotte, NC
- 2017 GTi Sport PP
Hey Cliff did you add the PVC elbow and drain tube?
I bit the bullet and installed one of these today. At the very least it will make it easier and less messy to transfer the contents of the can into whatever container I have on hand. Fumoto F106SX, M14x1.5: Amazon product page.
Thanks!Nice build!
No thanksLook into Endless pads and fluid.
-2.4 on my last alignmentWhen you ran those Ohlins with those GroundControl plates. How much max negative camber up front were you able to get? I had the same setup and got -2.4 without cutting strut tower.
You can no longer disable traction controlAlso, What happens to the car when your "DCC cancellers threw a hard fault" ?
I was out at Thunderhill West yesterday and I am still having VWR catch can issues. I drained 650Ml (22 oz) out of the can this morning and that was after only 35 minutes of track time. I ordered a 06K103495BL PCV that a number of people on the forums have recommended, along with a BFI catch can. Hopefully this change will solve the problems I've been having with the VWR system.
Have you tried the A4/A5 PCV valve? It's the current revision for S3 and R. It ends in BL. I have it on my GTI and it solved my smoking issues on track.
My car is a smokeshow on cloverleaf on-ramps with BL. I think it is actually worsening and I don't recall my OEM one having any smoking issues TBH. Probably should have left it alone. Good luck.
Nice driving. West course is fun, looks like the air quality improved a lot in the last few weeks too.
I keep seeing this discrepancy. It seems like for half of people the BL plate solves their issues while the other half it makes it worse. WTF is going on. Installing my BL revision Sunday and will test at Laguna Seca in about a month. Really hoping to end up on the "improved" side of the fence.
I'm on IS20 work ots EQT stg 1 tune. I'm pretty sure diggs is on a bigger turbo and higher boost, so that might make a difference?
Retains oil in the engine under excessive braking G-forces. Oil pools at the front of the engine, leading to smoke clouds and ultimately oil starvation.
