LateAPXR
- Fort Wayne, IN
I JUST got home from dropping my kid off at school, and luckily this happened at low speed (15mph?) just as I was turning into my apartment complex and I was able to coast into my parking spot.
Car started running very rough, sounded like a Subaru, very low on power (could barely creep into first gear to make the turn off the main road), and the CEL started flashing.
Scanned for codes as soon as I got in and found lots of misfires on Cylinder 3 only.
The only possible "self-inflicted" engine items I have done so far are APR Stage 1, plugged up the noise pipe right after the Y inside the pipe using the cheap Home Depot method, and installed a boost gauge/tap.
I've checked both and both seem fine, I don't think this is boost leak related.
I'm guessing it's more of an ignition issue? Spark plug or coil pack?
What do you guys think? Log from the Engine Controller is below.
Freaking out about this a bit, any fast help would be greatly appreciated!
Wednesday,09,May,2012,08:39:51:10308
VCDS Version: Release 11.11.3
Address 01: Engine Labels: 06F-907-115-AXX.lbl
Control Module Part Number: 1K0 907 115 S HW: 8P0 907 115 B
Component and/or Version: 2.0l R4/4V TFSI 0010
Software Coding: 0403010A18070160
Work Shop Code: WSC 01279 785 00200
VCID: 3668B73E415C5C9
2 Faults Found:
000768 - Random/Multiple Cylinder Misfire Detected
P0300 - 001 - - MIL ON
Freeze Frame:
Fault Status: 11100001
Fault Priority: 2
Fault Frequency: 1
Mileage: 56171 km
Time Indication: 0
Date: 2000.00.00
Time: 08:15:12
Freeze Frame:
RPM: 3280 /min
Load: 48.2 %
Speed: 65.0 km/h
Temperature: 89.0°C
Temperature: 25.0°C
Absolute Pres.: 980.0 mbar
Voltage: 14.097 V
000771 - Cylinder 3
P0303 - 001 - Misfire Detected - MIL ON
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 56171 km
Time Indication: 0
Date: 2000.00.00
Time: 08:15:12
Freeze Frame:
RPM: 3280 /min
Load: 48.2 %
Speed: 65.0 km/h
Temperature: 89.0°C
Temperature: 25.0°C
Voltage: 14.097 V
Readiness: 0000 0000
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 56171 km
Time Indication: 0
Date: 2000.00.00
Time: 08:15:12
Freeze Frame:
RPM: 3280 /min
Load: 48.2 %
Speed: 65.0 km/h
Temperature: 89.0°C
Temperature: 25.0°C
Voltage: 14.097 V
000771 - Cylinder 3
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 56171 km
Time Indication: 0
Date: 2000.00.00
Time: 08:15:12
Freeze Frame:
RPM: 3280 /min
Load: 48.2 %
Speed: 65.0 km/h
Temperature: 89.0°C
Temperature: 25.0°C
Voltage: 14.097 V
