Cumulonimbus
- 12 000 feet up
I have an 2008 GTI, APR Stage1 with a drop in filter - owned since new so I know there's nothing wacky that's been done by prior owners
I have been having some crazy boost issues lately, unable to spool past 3-5psi, then if you tap the throttle a few times the boost comes back or spikes like crazy to 26+ psi. Bad gas mileage, waving boost from 8-15-8-15psi ETC
I unplugged the MAF and things seemed to be much more controlled and smooth, and my fuel mileage went back up!
So I bought a new MAF and took some logs....
Things replaced;
Rev D DV
PCV
Coilpacks
Plugs
Filter
Cam Follower
After changing the MAF things were still a bit wonky but the ECU seemed to re-learn things after a few pulls and everything was back to normal! I think.....
Can you guys check these logs and let me know what you think?
Heres a log in stock mode while I believe the car was 'relearning' after the new MAF - full throttle, spike in boost followed by huge boost loss, to gradual increase - consistent with the issues prior to MAF replacement.
Heres a stock mode log when I believe the ECU had re-learned and things seemed to be holding good...
Heres a log in Stage 1 91oct - Notice there is a weird dip around 5300-5500 rpm - this has been an ongoing issue for me since before the crazy boost issue and came up in all 3 logs I ran - any insite on this?!
Any pros out there with some expertise on this? Any other data values I should log? :thumbsup:
Things replaced;
Rev D DV
PCV
Coilpacks
Plugs
Filter
Cam Follower
