f0ggy987
- Massachusetts
Hi,
As the title says really, what's the best way to implement valet mode in a Eurodyne file?
Would it be through the rev limiter? I noticed that "rev limiter" is currently 1,000RPM above "rev limiter 2" - should I maintain this 1,000RPM difference?
Anyone know what the "speed limiter" does? Mine is currently set to 512.017142
I'm worried that using the rev limiter might be a bit crude - in theory someone could just drive around bouncing off the reduced limiter, which can't be good for the engine. Is there any alternative method/approach?
Thanks
Thanks
