I just installed an aftermarket unit on my Jetta 2007 MK5. Its got bluetooth, GPS, DVD, iPod, USB, MIcroSD and A/V Inputs. It's a very fine unit and sounds great. At first I got the infamous battery drain issue and was told that a canbus gateway upgrade was the way to fix the problem. After looking at the wiring schematics for the unit however I noticed that the harness have two 12V power leads, one for always on feed (yellow cable) and one for switched feed (red cable). So I ran an additional cable and installed a fuse tap on an available switched slot on my fuse box. I then cut the red cable on the harness (the one that came with my unit, NOT the factory one). That lead is marked ACC+ in my case, but test before cutting though. Finally after connecting the red wire to the new line, the problem was fixed. No need to change my canbus gateway. Everything works fine, no messages on my screen, wheel controls work fine and no battery drain issue.
