PARKER
- Santa Clarita
Any benefits to running an aftermarket thermostat to keep the engine cooler? Any problems is what I should be really asking.
Most modern cars have electric fans and even electric thermostats in some cases. Sure you can put in a lower thermostat but the fans are just going to come on later and run for less time. You'll still end up running the car at the same temp.
Also with modern electronics the car runs differently at different temps so lowering the temps can put it into a cold start map and hurt performance.
Besides this damn thing makes my whole garage HOT after I park it. lol
Really? It makes the engine run around 175 instead of around 190. I know on motorcycles you just change out the coolant for something like water wetter and makes everything run cooler and better. So I was thinking about doing the same thing in my car, but I would have to change the thermostat to one that would allow the engine to run cooler. Otherwise it will just regulate it at the same temp. Correct?
I think the CATs are responsible for this. If you go for a DP with high flow cat you'll find your garage will not be as hot.
I also was wonder what else can be done to keep the car cooler on HOT days and also driving the car hard!
I know a FMIC would help, also would chaging the rubber hoses??
