markcaughey
- Glasgow
OP is your gti a 09?
Need some help here as the title says I'm getting the dredded abs, esp, tyre monitor lights up on the dash AGAIN. This happened to me about a year ago and the cause was a corroded wheel bearing (rear drivers side) abs sensor couldn't get a reading therefore throwing the code. When I first saw the warning light I thought it was the same issue but opposite side. But it seems different this time as before all the lights where on constant and couldn't be reset via the reverse method. But this time the way it goes is when I get in and start the car just abs light comes on and after a few seconds the other 2 come on and they do go out when I revers the car and apply the brakes but only stay off until I begin to drive.
I had this exact the same problem with a previous mk5 TDI I owned. However I had vag com at the time and I managed to disable the esp system wich put the light out.
I don't know anyone with vag com now and can't get a scan to find fault codes
Some people are saying it could be wheel abs sensors and have been told if it is the abs pump failure it would just be abs light on and no others. Also a few have said just pull the fuse for the abs pump !
What's ur opinions on the ?
