iamjordayy
- Grand Cayman
- 2006 Golf GTI
Hi Guys,
For months I've been having an issue with my car. its a 2005 MK5 GTI. If I'm driving aggressively taking corners sharp i sometimes get 3 beeps, the esp, abs and handbrake lights flash, once this happens I lose abs and traction control (which makes it super easy to lose control). Also, if I'm at a standstill and floor the car to where the wheels spin excessively the same happens. When this happens i have to pull off, restart the car and the lights go away. I have replaced pads, wheel speed sensors, change brake fluid but the issue persists. At times if I have to brake hard in the case of an emergency the same issue happens. I scanned the car and get the same error every time. i am really hoping its not a faulty abs unit. Can you guys assist?
Weirdly, if I turn off the ESP and do a launch i can spin the wheels without the the lights coming up.
Address 03: ABS Brakes Labels: 1K0-614-517-MK60AT.clb
Control Module Part Number: 1K0 614 517 R HW: 1K0 614 517 R
Component and/or Version: ESP FRONT MK60-AT 0103
Software Coding: 0037506
Work Shop Code: WSC 00046 412 00000
VCID: 3635268B944F34CBB9E-8062
1 Fault Found:
01130 - ABS Operation
008 - Implausible Signal - Intermittent
1 Fault Found:
1 Fault Found:
1 Fault Found:
1 Fault Found:
1 Fault Found:
