-jakrbt-
.:R32 OG
- North Texas
The first pic is nice and clear, the other is a little out of focus, did you do any post processing on the first one? Looks like it based on the trees/skyline.
run at the lowest aperture you can is the best starting point, you want the lens to be fast. I'd recommend picking up a prime lens like the 35mm 1.8G for things like this.
That's why I said you have to open the aperture all the way up. The 35mm is limited to 35mm, they also make a 50mm and an 85mm but the cost goes up, the 35mm prime is about $200. You have to have a lens with a larger aperture to get enough light in for a faster shot. Also did you adjust the ISO?
Up the ISO a bit when you are in bright sunshine like that, itll help. You can just shoot in manual, open the aperture all the way up and the set the speed accordingly.
I'm not sure if there are differences between those two lenses.
All pics were adjusted using Camera RAW and then some minor processing using CS4. The action shots are a little fuzzy. Haven't quite figured out how to shoot them clearly just yet. Used "Sports" mode on the D5000 for those. Suggestions on how to shoot action shots better?
