ricekillervdub
OEM K04 Equipped
- Istanbul,Turkey
- Seat Leon Cupra 1P
Its a 2006 R53 Mini Cooper S.... I am gonna sell it soon for a MKV Gti...
Engine:
Cometic .027 Head Gasket
ARP Connecting Rod Bolts
ARP Main Studs
ARP Head Studs
CNC Ported/Polished Cylinder Head
CNC Ported/Polished Manifold
78 mm. CP Forged Pistons (Increased bore by 1mm)
Pauter Forged Connecting Rods
Ferrea Forged Oversized Valves
Ferrea Forged Valve Springs and retainers (Full Ferrea Valvetrain)
Schrick Camshaft
Spec Stage 3 Clucth Kit
Spec Lightened Aliminium Flywheel
Supersprint Header
Supersprint Cat-delete
Alta v2 Black Stealth Cat-Back Exhaust
Alta v2 Top mount Intercooler Kit with Water Spray
Alta v2 %19 Reduced s/c Pulley
Alta v2 %4 Crank Pulley
Alta %5 Alternator Pulley
Alta v2 Cold Air Intake
Alta v2 Intake Box
M7 Big Throttle Body
Detroit Tuned Bypas Valve
480 cc Injectors
Alta slicone Radiator Hose Kit
Alta Oil Catch Can
MSD Ignition Coil
Nology Hot Wires
NGK Iridium X Spark Plugs
Alta Intercooler Slicone Couplers
M7 Engine Thermostat
Alta Transmission Mount Upgrade
Alta Engine Mount Upgrade
Whiteline bushings
Quaife LSD
Sprint Booster (Quick Throttle response)
Aem UEGO 6 in 1WideBand Sensor
Defi EGT
Defi Link Control Unit
Walbro 255 LPH fuel pump
AEM Methanol injection kit
JCW Supercharger ported by Steigemeier
Exterior:
Wilwood Big Brake Kit ( RED Drilled ) 328 mm
Goodrich Front Steel Brake Lines
Goodrich Rear Steel Brake Lines
Omni Competition Rear Brake Rotors
Eibach Lowering Springs
Koni FSD Shocks
Eibach Sway Bars
Konig Zero ``17 Black&Red Wheel
215/40/17 Dunlop Tires
JCW Front Bumper
JCW Rear Bumper
JCW Side Skirts
Forge Mini Ram air hood scoop
Interior:
Custom Black Matte Board Dashes
JCW Shift Indicator
AEM Boost Gauge
Thats all I can remember for now...now the pics...
Its not a MKV but soon it will be replaced by one, hope you guys arent wearing horse spectacles and see only mkv's
Engine:
ARP Main Studs
ARP Head Studs
Schrick Camshaft
Supersprint Header
Alta v2 Intake Box
480 cc Injectors
Alta Oil Catch Can
MSD Ignition Coil
Nology Hot Wires
Whiteline bushings
Quaife LSD
Defi EGT
Exterior:
Koni FSD Shocks
Eibach Sway Bars
JCW Front Bumper
JCW Rear Bumper
JCW Side Skirts
Interior:
JCW Shift Indicator
AEM Boost Gauge
