Ant_mkv
- Long Island, NY
73k miles on the body
8k miles on Built motor
Custom dyne tune 378WHP 373WTQ
Integrated Engineering forged drop-in rods w/ARP rod bolts
ARP Head stud kit
Supertech Exhaust valves
Supertech Intake valves
Supertech valve spring/ titanium retainer set
Neuspeed crank power pulley
Clutchmasters FX400 sprung 6puck-2k miles
800hp rated axles from the drive shaft shop+warranty
Frankenturbo F23T mixed flow turbocharger
RS4 injectors
Golf R 3bar Map Sensor
Auto tech High Pressure Fuel Pump
145bar Fuel Pressure Regulator
GFB DV+
42 Draft Designs 2.5"resonated catback exhaust
42 Draft Designs ultimate oil catch can solution
42 Draft Designs 10mm front wheel spacers + extended lugs
3" catless downpipe
BSH throttle pipe
Evolution Motorsport cold air intake
H&R Ultra Low Coilovers
H&R 28mm front sway bar
Hotchkis 27mm rear sway bar
Whiteline Heavy duty front endlinks
Solid mounts for front control arms
BFI Stage 2 Complete Engine mount
BFI Stage 2 Complete Transmission mount
BFI Stage 2 Torque Arm Insert
Dieselgeek Sigma 6 Speed Short Shift kit
Notch filled hood
Badge less grille
Vented fog light grilles
ECS Tuning electronic vent mounted boost gauge
735 gram Raceseng shift knob
New brakes all around
I have every receipt/service record that's been done to the car since engine rebuild
Interior 9/10
Exterior 7/10
Comes with Eurodyne Maestro tuning suite
More pictures upon request
$10,000 OBO
ARP Head stud kit
RS4 injectors
GFB DV+
3" catless downpipe
BSH throttle pipe
Notch filled hood
Badge less grille
Interior 9/10
Exterior 7/10
$10,000 OBO
