Chico
- Brizbekistan
For Sale
Volkswagen Golf Mark V GTI
May 2007 Build Germany
22 August 2007 Delivered Gold Coast Volkswagen
3-Door
6-Speed DSG
Candy White
Anthracite Leather
35,000km NOW 38,000
Qld Registered to August 2010 NOW FEB 2011
No Track Work
No Accidents
No Warranty Claims
Trouble - Free
Smoke and Pet Free
Improvements...
APR Stage 2+ ECU Software (Stage 2+ Pump Performance)
Forge Motorsport Cold Air Intake and Heat Shield, Intake Tube Wrapped with Thermotec Header Wrap
VW OEM Open Fog Light Grilles
VW OEM Piston Type D Diverter Valve
Neuspeed Torque Arm Insert
BulletProof Speed Hardware Positive Crankcase Ventilation Revamp (PCV Revamp)
APR FSI High Pressure Fuel Pump
Custom Exhaust...
3” Down Pipe
200 Cell Per Inch Magnaflow Catalytic Converter
14” Long Torque Tube after Cat
Muffler before Rear Axle
2.5” Cat-Back System Based on AWE Layout
Infinity Window Tint – Lifetime Warranty
Khumo Ecsta SPT KU31 235/40/17 (9000km old – Rotated Front to Back 4000km ago)
Whiteline Anti-Lift/Caster Kit
Whiteline Front Lower Control Arm Bush Kit
Whiteline 24mm Blade Adjustable Solid Rear Sway Bar
Whiteline Rear Trailing Arm Front Bush Kit
Defi Blue Boost Gauge in psi unit of measurement
OSIR Vent Mount for Boost Gauge
Osram H7 Night Breaker Dipped Beam and Parking Lights
GTI Seat Inserts
(Only obvious sign of modification is the Cold Air Intake and slightly larger twin exhaust tips – otherwise looks stock)
Original Equipment Included in Sale
Complete Original Exhaust System
Complete Original Engine Cover, As New Panel Filter
Complete Original Diaphragm Type Diverter Valve
Forge Diverter Valve (Was removed to fit OEM Piston Type D Valve)
Complete Original PCV
Original Headlight and Dipped Beam Bulbs
Original Fog Light Grille Surrounds
Original Cam Follower Bucket (shows ‘normal’ wear but replaced when APR FSI Pump Fitted)
Complete Original Drivers Side Vent
(In other words, EVERY SINGLE THING needed to return to completely stock if needed)
Service History
12/09/2007 - 1068km - 1000km Check Up - Gold Coast Volkswagen
05/10/2007 – Torque Arm Insert Fitted
01/02/2008 – Full Turbo-Back Exhaust Fitted
18/03/2008 - Oil @ Oil Filter Change – Mike Weber Prestige & Performance
??/04/2008 – APR ECU Tune
23/09/2008 – 15,084 km - 15,000km Service - Mike Weber Prestige & Performance
28/10/2008 – BSH PCV Fitted – Mike Weber Prestige & Performance
04/01/2009 – OEM Open Fog Grilles Fitted
??/02/2009 – Oil & Oil Filter Change - Mike Weber Prestige & Performance
08/05/2009 – APR FSI Pump & New Cam Follower Bucket Fitted – Harding Performance
13/05/2009 – Oil & Oil Filter Change - Mike Weber Prestige & Performance
28/08/2009 – 26, 500km Kumho KU31 235/40/17 Fitted – Option 1 Garage
21/10/2009 – 27,931km - 30,000km Service, Wheel Alignment & Balance, Fit W.A.L.K & Bush Kit - Mike Weber Prestige & Performance
19/01/2010 – 30,999km Oil & Filter Change, Pollen Filter Changed, VW OEM DV Fitted, OSIR Boost Gauge Fitted Brake Fluid Flush & Replace, Front to Rear Wheel Rotate - Mike Weber Prestige & Performance
??/05/2010 - Will get Mike to fit RSB and Trailing Arm Bush Kit & Do RWC (Safety Cert) for Transfer. Rotate Rear to Front Tyres.
Fuel Consumption
http://www.fuelly.com/driver/chico/gti
$35,000 - Open to Sensible Offers - PM to Contact - No Part Out Checked my lease payout figure - it is $27,442.07 - I am happy to accept this figure for the car
Selling from my Business so can provide a GST Invoice (This means, if you are buying it for your business, you can claim back the GST, making the car effectively under $25K)
Pictures
3-Door
6-Speed DSG
Candy White
Anthracite Leather
35,000km NOW 38,000
No Track Work
No Accidents
No Warranty Claims
Trouble - Free
Smoke and Pet Free
Improvements...
Custom Exhaust...
3” Down Pipe
GTI Seat Inserts
Service History
Fuel Consumption
Pictures
