justinh510
- columbus ohio
- vw mk5 gti
Hello, I have a 2008 GTI 2 door, about a year or two ago,
i had an electrical problem ( my fault i wired something up wrong )
It melted the body control module under the driver side dash causing everything electrical to go crazy.
I ordered a used BCM from a mk5 jetta online to replace it. however one of the connectors to the BCM melted as well, so i went to the junk yard and got one off a jetta of the same year to just splice to the existing wires. everything matched exept a yellow and white striped wire. there wasnt a wire coming from the junk yard connector. however everything started and ran perfectly fine.
its been so long so i don't remember 100% but i think the tail lights worked too.
it wasn't until i got pulled over for driving at night with no tail lights at all.
the brake lights, turn signals, reverse and hazard lights all still work as they should.
when i pulled the headlight switch i saw a small yellow and white striped wire.
everything in the back is grounded well and the connectors are clean.
ive checked almost every fuse in the car and they all look fine ( can't find a accurate fuse diagram online to know exactly what fuse to look for )
I feel it could be either something with the programing with the BCM, or possible the yellow and white wire that is just hanging there connected to nothing.
does anyone have any ideas or know what direction i should head in?
I was not in the position to really mess with it much
so i've been just driving during the day
I have Pictures after i post this ill get them on the pc and upload them.
thank you
thank you
