So, just playing this out in one's head... let's say it is only good for 25 psi as the article claims (likely based on VW specs for I'm sure). So, when he's hitting something like 30 psi, the DV would clearly be opening via force rather than an electrical signal due to, I'm guessing, the new ECU programming from APR allowing such high compression rates. If that's the case, then the APR program would be asking for higher compression (air density) from the turbo... the DV would be leaking compressed air between 25 - 30 psi, and since the DV is post-MAF, I'm guessing the engine management software would expect an air charge of up to 30 psi and wouldn't know it's less and would not trigger a CEL, either. Due to the DV leak, the pressure would be much less from the turbo, therefore leading to a lean condition in the cylinders in compression strokes (ie - cyls 2 and 4 where the ECU retarded spark for *some* yet unknown reason). The lean condition may lead to misfires/knock and the ECU then retarding spark ad hoc... even though the APR programming is still calling for advanced timing at those high rpms.
Btw - that differences between the DV and WG get confusing. I was doing a bit more reading and I see that the DV does actually recirculate the over-pressure back into the intake as opposed to the atmosphere. That said, what about your reference to the MAF sensor max capacity? I didn't look back, but if the DV is hitting 30 psi (even after the DV leak, meaning pressure could be even higher)... then a LOT of excess air is being recirculated back into the intake... this could create a scenario, again, where there's more air in the intake streak than the MAF can calculate and it just maxes out the ECU's call for fuel... leading, again, to a lean condition that are in their compression strokes.
What do you think?
