mkhighfive
- cleveland ohio
- gti mkv
so i just installed ko4 kit and im trying to figure out what is causing this problem. it only happens when the car is pretty cool and i havent driven it too hard maybe for 15-20 min after start up. so ill be getting on the highway in 3rd gear, and floor it and the boost gauge will spike to 30 psi or above. i also threw a cel,
Address 01: Engine (CCT) Labels: 06J-906-026-CCT.clb
Part No SW: 1K0 907 115 AE HW: 1K0 907 115 AA
Component: 2.0l R4/4V TFSI 0030
Revision: AAH03--- Serial number: VWX7Z0H53N37XO
Coding: 0403010A18070160
Shop #: WSC 64801 384 16449
VCID: 69F76C8E3911
1 Fault Found:
008342 - Post-Catalyst Oxygen (Lambda) Sensor Correction; Bank 1: Too Lean
P2096 - 000 - - - MIL ON
Freeze Frame:
Fault Status: 11100000
Fault Priority: 0
Fault Frequency: 1
Mileage: 68013 km
Time Indication: 0
Date: 2000.00.00
Time: 21:36:45
Freeze Frame:
RPM: 2147 /min
Load: 26.7 %
Speed: 73.0 km/h
Temperature: 95.0°C
Temperature: 33.0°C
Absolute Pres.: 970.0 mbar
Voltage: 14.097 V
Readiness: 0000 0001
i have an O2 spacer in as well.
all my other mods are in my sig.
could this be a vacuum leak problem?
tomorrow im going to check the N75 valve, any other recommendations for things i should check.
i just dont feel comfortable with the fact that it is boosting so high as i dont believe that is normal. also what could be causing the engine running lean?
thanks for the input guys!
VCID: 69F76C8E3911
1 Fault Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Mileage: 68013 km
Time Indication: 0
Date: 2000.00.00
Time: 21:36:45
Freeze Frame:
RPM: 2147 /min
Load: 26.7 %
Speed: 73.0 km/h
Temperature: 95.0°C
Temperature: 33.0°C
Voltage: 14.097 V
