overboost problem
mkhighfive
cleveland ohio
gti mkv
so i just installed ko4 kit and im trying to figure out what is causing this problem. it only happens when the car is pretty cool and i havent driven it too hard maybe for 15-20 min after start up. so ill be getting on the highway in 3rd gear, and floor it and the boost gauge will spike to 30 psi or above. i also threw a cel,
Address 01: Engine (CCT) Labels: 06J-906-026-CCT.clb
Part No SW: 1K0 907 115 AE HW: 1K0 907 115 AA
Component: 2.0l R4/4V TFSI 0030
Revision: AAH03--- Serial number: VWX7Z0H53N37XO
Coding: 0403010A18070160
Shop #: WSC 64801 384 16449
VCID: 69F76C8E3911
1 Fault Found:
008342 - Post-Catalyst Oxygen (Lambda) Sensor Correction; Bank 1: Too Lean
P2096 - 000 - - - MIL ON
Freeze Frame:
Fault Status: 11100000
Fault Priority: 0
Fault Frequency: 1
Mileage: 68013 km
Time Indication: 0
Date: 2000.00.00
Time: 21:36:45
Freeze Frame:
RPM: 2147 /min
Load: 26.7 %
Speed: 73.0 km/h
Temperature: 95.0°C
Temperature: 33.0°C
Absolute Pres.: 970.0 mbar
Voltage: 14.097 V
Readiness: 0000 0001
i have an O2 spacer in as well.
all my other mods are in my sig.
could this be a vacuum leak problem?
tomorrow im going to check the N75 valve, any other recommendations for things i should check.
i just dont feel comfortable with the fact that it is boosting so high as i dont believe that is normal. also what could be causing the engine running lean?
thanks for the input guys!
dubbin
All in, All out..
Salt Lake City, UT
09 GTI
well the things that control boost levels, or prevent the turbo from overboosting is the n75 valve and the wastegate. can you log the n75 cycle? and your engine is running lean cause your over boosting, lol not enough fuel being shot in their for that 30psi.
Alex/A.W.E.
Willow Grove, PA
VCID: 69F76C8E3911
1 Fault Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Mileage: 68013 km
Time Indication: 0
Date: 2000.00.00
Time: 21:36:45
Freeze Frame:
RPM: 2147 /min
Load: 26.7 %
Speed: 73.0 km/h
Temperature: 95.0°C
Temperature: 33.0°C
Voltage: 14.097 V
Adam,
I posted this in your main build thread, but wanted to post here as well to make sure you saw it.
The overboosting problem you're experiencing sounds like an N75 valve issue. Can you make sure its installed properly and email me the logs once you have them?
My email is aderderian@awe-tuning.com. Once I have them I'll show them to our team and see what they think.
mkhighfive
cleveland ohio
gti mkv
alex, ill do that today and email them to you tonight. i looked at the valve last night and didnt see that any of the lines were damaged. do you have a diagram the i could see to make sure the hoses are connected to the right places?
BaranE
Istanbul
Here's one.
mkhighfive
cleveland ohio
gti mkv
Was it your n75 valve?
mkhighfive
cleveland ohio
gti mkv
Alright ill look again cause I did it late ladt night
mkhighfive
cleveland ohio
gti mkv
tweaked?
mkhighfive
cleveland ohio
gti mkv
i assume youre talking about adjusted? and no i didnt adjust anything i took it out of the box and put it in my car haha no adjustment
mkhighfive
cleveland ohio
gti mkv
is it possible that my boost gauge is malfunctioning? ill do a boost log to see the actual pressure. is that a possibility?
