PetrolHead
When's the next track day
- Motor City
- MKVI GTI
There's a lot going on under the hood of your GTI. While the factory dash gauges do a good job of keeping track of the vitals: Speed, RPM, Fuel, Water Temp, and warning lights, there is still vital information missing. Mainly, boost. On a turbocharged engine, having a method of monitoring boost pressure is vital to diagnosing issues and making sure that your turbocharged engine is performing to its fullest potential. Another vital statistic is oil temperature. Your turbocharger is lubricated using engine oil, and if it gets too hot or is too cold, you'll need to adjust your driving habits accordingly. From the factory, Volkswagen ignores these two vital gauges, but that's where Podi has come in to offer a complete OEM-grade solution to full monitor engine conditions. The following how-to was performed on a 2009 Volkswagen GTI 2-door equipped with a TSI 2.0-liter 4-cylinder engine and a 6-speed manual transmission. This first portion is only for the boost gauge. Instructions for the oil pressure/oil temperature gauge are to follow. Please keep in mind that your actual car may vary, however this installation was designed keeping all variations of the MKV (2006-2009) GTI's in mind.
Remember that installing equipment on your own vehicle is done so at your own risk. I, nor Podi are responsible for any damage that may me incurred on your vehicle. This how-to guide is intended to be just that. A guide. If your vehicle differs from anything seen here, please use your best judgment while keeping safety the number one priority.
Tools and Materials list:
Flat-head screw driver
Phillips-head screw driver
3/16” hex screw driver
13mm Socket
10mm Socket
Needle nose pliers
Channel lock pliers
T20 Torx screw driver
T15 Torx screw driver
~20 feet of small gauge wire
Electrical tape
Add-a-circuit connectors
Zip-ties
Removing the engine cover, airbox, and battery:
Step 1:
Pop your hood and remove the engine cover. On the TSI, this is accomplished by gently pulling up on each of the four corners. The cover will simply pop off, and set it safely off to the side.
Step 2:
Using your phillips head screw driver, loosen the 8 screws holding on the airbox. Note that the screws will not come all the way out. This is a safety feature so that you don't lose your screws.
Step 3:
Using the channel locks, clamp on the band clamp on the air intake and gently remove the intake tube with the airbox. You can leave the mass airflow sensor connected, just place the tube out of the way, keeping in mind that the mass airflow sensor is still connected
Step 4:
Remove the cover over the battery and place it off to the side. Then, remove of the front lower battery cover by inserting a flat head screwdriver into the tabs holding it on. Finally, using the 10 MM socket, disconnect the battery terminals.
Step 5:
Using the 13 MM socket, remove the bracket holding on the battery on the bottom left and carefully remove the battery, placing it off to the side. Then, remove the lower rear battery cover by prying up on the connection tabs. There are three. One on each side, and one on the rear. Disconnect each side first, then the rear should pop out easily
Installing the boost tap, boost line, and filter
Step 6:
Locate the tube running from the intake manifold to the cylinder head on the front of the engine
Squeeze the opposing serrated sections of the connector and gently pull the tube off the intake manifold port
Step 7:
Attach the longer of the two supplied boost lines to the boost tap
Step 8:
Insert the gasketed end of the boost tap into the port on the intake manifold. Make sure the tabs on the boost tap are over the ridge on the intake manifold to keep it stable.
Step 9:
Snap the tube onto the open end of the boost tap. The result should look like below.
Step 10:
Route the boost line below the lower airbox and along the right side of the battery tray, in between it and the fusebox. Cut the line so it ends at the middle of in between the battery tray and fuse box. Install the filter with the arrow pointing toward the rear of the car on the end of the boost line attached to the boost tap, and install the rest of the boost line to the other end of the filter.
Routing wires to the cabin
Step 11:
Follow the main wiring harness to where it meets the firewall. Around the joint is a baffled rubber boot. Using the flathead screwdriver, poke a hole in the boot, and insert the boost line and (if required) a wire for the oil pressure and/or temperature gauge. Some people prefer to use a straightened coat hanger to assist inserting wires through the boot into the cabin. I found it to be pretty simple just using the bare wires. If you were to use a coat hanger, tape the boost gauge and wire to the end of a straightened coat hanger and push the coat hanger (with wire and boost gauge attached) through the new hole in the wire boot. Only insert the tube and wires a few inches. You'll pull it though in a few minutes.
Dismantling interior and wiring for gauges
Step 12:
Remove the fuse panel cover by inserting a flat-head screwdriver into the opening in the bottom and place the fuse panel cover safely off to the side
Step 13:
Remove the headlight switch by pushing in on the knob and while the knob is in, turn clockwise. This may take a few tries, but you'll be able to tell when it catches.
Disconnect the wire connected to the headlight switch by pressing on the tab on the left side and pulling.
Step 14:
Remove the 5 screws holding on the lower left panel using the T20 Torx bit. Three on the bottom:
And two on the top. One here:
Gently pull on the piece that runs along the bottom of the gauge cluster that the vinyl cover to the steering column is attached to and pop it off. Behind that is the last screw:
Now, pull out and to the left and the lower left panel will come off and detach the wire connected to the dimmer switch by pressing on the tab on the left side of the connector (per the image)
Step 15:
Remove the bottom dash piece by removing one final T20 torx screw and wiggling it loose
And let it rest on the floor
Step 16:
Feel for the boost tube and wire (or coat hanger if you chose so) at the rubber boot on the fire wall and pull everything all the way through.
Step 17:
Route the boost tube and wire through the dash and into the fuse box area.
13mm Socket
10mm Socket
Needle nose pliers
Channel lock pliers
Electrical tape
Zip-ties
Step 1:
Step 2:
Step 3:
Step 4:
Step 5:
Step 6:
Step 7:
Step 8:
Step 9:
Step 10:
Step 11:
Step 12:
Step 13:
Step 14:
Step 15:
Step 16:
Step 17:
