I need help.
My car now is pulling to the left. I told them I'm bringing it back. First I need to take a much needed dump. Can I get help on what all the settings should be? Maybe cause its lowered I can't use the original settings... I have no clue.
I don't believe it's pulling left when you release the steering wheel. It's turning left
when you're steering straight, right?
These are two different things. :wink:
Camber and caster are almost perfect. It's just the toe settings which are crappy.
I wonder why the shop didn't correct them as toe is easy to adjust both on front
and rear. No need to content oneself with these poor values.
It doesn't matter if you have +0.04° or +0.06° of toe in, the point is you have
them equal on both left and right !!
Visit the shop again. If they anyway adjust the toe in settings get the rear camber
aligned as well. I'd recommend -1.2° to -1.3° for less and more even tire wear.
BTW, more ride height > less front camber > less tire wear. :lol:
TT arms are NO tire wear solution. TT arms increase camber, not just add adjustability.
On a lowered GTI you will at least get -2° of camber with them.
