Symptoms of a leaking Trans Pan?
alfmoonspace
Potato Land
mrRabbit.
You posted on another thread about your trans not being able to get our of first gear. Your mechatronics unit is probably malfunctioning, give your local dealer a call and tell them your vin number. If your car is under the recall (you will have an extended warranty), they should swap that out for you.
mrRabbit
Orlando
Here's the sad part, I went to them and they told me that the solution was to keep the brake pressed until I engage the gear that I want to select and then release it and it should get rid of the flashing gears indicator. But the thing is, the flashing occurs as soon as I start the car. I really don't know what to do.
I read some people had it happen to them because they had a leak, so I'm basically trying process of elimination to identify the problem. It's really stressful.
