Dynjo
- Chicagoland
HP+ pads are only rated up to 800 degrees F
I routinely see 1100 - 1300 F, and that's with crappy old street tires and a crappy old driver. It would only be higher with R-comps and a hotshoe.
How are you measuring?
http://www.pegasusautoracing.com/productdetails.asp?RecID=4974
I put a dab of temp-indicating paint on a rotor vane on each wheel and sometimes a dab on the backing plates.
I have also put temp-indicating stickers on on the calipers but really did not see much happening there, leading me to conclude the brake fluid is not too temperature-challenged.
Laser guns are not capable of capturing the peak temperatures seen during a lap, making them essentially useless for this application, unless, of course, you have one mounted on the suspension and you record the output with a datalogger. That would be cool, but not feasible for the common man.
I managed to induce some pad-fade on the yellowstuff pads during my moronic attempt at bedding (successive 70MPH-5MPH braking every 10 seconds) . As pad fade needs about 800C I have no trouble of believing that 800F is very easily exceeded on a suitable track.
I YellowStuff doesn't work try Pagid, Performance Friction or Endless.
Most european professional teams run these brands.
One other point to bring up... if you guys care about car appearance at all, RB may not be a great idea. In theory it is going to be shedding less metal, but you have to figure that when it does come off it is going to flake off since it is so much harder than stock. That is going to do hell on paint.
Just a wild-ass guess, but it is something to consider since I know some people are putting RB on non-"go" cars that are "moar low."
