Followed this guide last weekend when changing my clutch and got all in place at the first attempt. Never done any clutch changing before but with this guide it is easy! It took my almost two days as i was taking it slow but it got me right true it without big issues, thanks!!
Advise from me is to remove both flange shafts of the transmission (gearbox). If not removed they are in the way when you try to pull down the transmission and when you need to push it back. Just remember to empty the transmission of the oil before removing the transmission from the car. With the flange shafts removed the transmission is opened up and oil will spill out. This way you can put the oil back when you are done or simply just replace it with new.
