That sounds like the touchscreen might be defective. A firmware update will unfortunately not change the CarPlay USB requirement. It requires a USB connection (though there are wireless adaptors but they still connect through USB).hi. Just bought 2017 VW Tiguan S. Current installed software train version is MST2_US_VW_PQ_P0359T. I downloaded MST2_US_VW_P0367T_3G0919360CL file from mibsolution.one . copied the contents of the file to formatted sd card and inserted it to the sd reader. i immediately got a message saying the software update is available. but when i got to menu->system information->firmware update it looks for firmware update but doesn't find it and gives me a message that update is not found. so what should i do?
the reason i want to update it is the touchscreen is not responsive on the edges of the screen. the middle works fine. for example, i can click and enter anywhere, but i cannot click the "go back" button on the upper right of screen. or if i want to type anything the keyboard letters at the edge of the screen are not clickable. Also it says i can only use apple carplay through usb. i wonder whether the update will allow connection through bluethooth. i can still connect to the infotainment through bluetooth and can use voice commands, calls, media, but not navigation.
thanks in advance
Are you unable to upgrade to the Delphi unit to get the app button working?Hi all,
I have a ZR Technisat unit (3Q0035876) that recently developed the reboot bug every few minutes with the Nav SD card inserted (CID unlocked). I've read that a firmware update can fix this issue, but I'm already running the newest unit-supported firmware (MST2_US_VW_ZR_P0254T). I know I can technically try to bump it to the P0367T firmware and I've prepared everything to do it, but I have some points of confusion and a couple of questions:
Is it possible to fix this issue without changing the firmware? Would the 03xx firmware even fix it?
I also have the 8" glass screen with the non-functional App button installed. Is it possible or advisable to update to the EU facelift firmware for the ZR units to enable the App button and updated menu layout? Would the hardware even support it? If so, what would be the differences between the EU and US firmware and would it be problematic? Some posts seem to suggest it's possible, but I have no idea what all that would imply.
There's been so much information it can be hard to sift through. I'd be appreciative of any help anyone can give me.
Thanks!
I'd prefer not to spend the money and hunt one down if I don't have to.Are you unable to upgrade to the Delphi unit to get the app button working?
