itisagoodname
- Bay Area, CA
- '08 G37S
Sponge...I have answers from APR regarding your inquiry and observations / hypothesis. Its late so I'm not going to post now...but stay tuned in the morning!
*tuned in*
K, so If Im going stage 1 91octane APR, is that running the FP software that requires 130 bar? Alot of this is not making sense to me, I dont understand alot of this terminalogy, so please put it into lamens terms for me so I can understand. Most of the people thatve posted in this thread about bad shit with APR have the stage 2 software, im going stage 1, any real problems i should be concerned with with the oem FP? And if I go stage 2 later, should I feel its absolutely necessary to go with the apr FP and nothing else?? This kinda makes me on edge bout going with APR software...:iono: :iono:
Someone please help me feel better about going with apr stock FP.
Z
Cool, thanks all. Still Id like info on this pcv fix and if I really should look into it or not?
If you get Stg 1 and are boosting fine, and then see that your boost has dropped a consistent 1-2psi across the whole rpm range, that's a sign of a bad pcv.
Hmm, might be a good time to look into that awe boost gauge eh? How hard is the install on that gauge, and will that just hook up to the other hole thats plugged right now on my vtwin?? Wasnt sure if thats what ive heard or not?
APR has been using 130 Bar for a while. On there old SW it wouldn't kick in till after 5k, on their FP SW, it kicks in much earlier. It is my belief that APR is riding the Fuel pressure limiting valve on their FP SW, you can find my comment earlier in this thread. If this is indeed the case (which I do believe is the case from logs I have seen) then a pump that does more volume would only accelerate the problem.
While the 130bar idea is great way to get lower injector times. (more fuel through the injector in shorter time) I don't think the whole plumbing part was thought out as carefully with the larger pump.
My previous post described what could be happening with the plunger on the peak on the cam stroke. This image shows what could be happening on the intake stroke if the relief valve is constantly being used. Id strongly suggest that people with a FP and 130 bar SW log a pull to redline and let off the gas. See if there is a spike during overrun. PM me for details.
Noregrets, This is AWESOME info! Thanks for comin through!
