mrmatto
Yeah 3rd feels pretty good. Top of 3rd starts to feel the heat if it’s warmer out. But not too noticeable.With DSG, are you feeling any big drop off in 3rd, probably 4th for you, based on gearing?
I'm going to miss the 16th, but I can't wait to hear how your car feels on course.Yeah 3rd feels pretty good. Top of 3rd starts to feel the heat if it’s warmer out. But not too noticeable.
I’m likely gonna miss it too lolI'm going to miss the 16th, but I can't wait to hear how your car feels on course.
We're slackers.I’m likely gonna miss it too lol
Damn dude . Open your own tire shop already.We're slackers.
Remember last month when I bought 245 40 17 RE71RS's over the V730, because they were same price in 17's?
235 35 19 there's a $100 per tire difference. Still went with the stones, they were so impressive in the month I had them, I just bit the bullet.
i switched to blanks because the only 2pc fcp stocks in 340mm are 034 shit, at least from what i foundYou're probably right, but was looking at the 2 piece, some titanium spacers, RS3 deflectors, because I'm going to have to use the stock calipers. I'd keep the 2 piece for track only and use stockers for street and autocross, you're probably right, blanks make more sense.
I was mistaking the mk8 R rotors, which are 357mm. You're right, they don't have them. ECS seems to seem the CS 2 piece though.i switched to blanks because the only 2pc fcp stocks in 340mm are 034 shit, at least from what i found
So I filled up with 93 Oct and ran the car a couple of days. I know it's tuned to run on 87, but 3rd gear feels much better with 93. It must have been pulling timing and/or boost.Yeah 3rd feels pretty good. Top of 3rd starts to feel the heat if it’s warmer out. But not too noticeable.
Makes sense. I’ve been running 89 and it seems to do well. 93 is prob overkill but who knows.So I filled up with 93 Oct and ran the car a couple of days. I know it's tuned to run on 87, but 3rd gear feels much better with 93. It must have been pulling timing and/or boost.
From what we know 2019+ cars have a high-octane learning mode, so they should be adding at least a few degrees of timing on premium.So I filled up with 93 Oct and ran the car a couple of days. I know it's tuned to run on 87, but 3rd gear feels much better with 93. It must have been pulling timing and/or boost.
I don't know if that's the same on the mk8. A few people have dyno'ed these engines on 87 vs. 93 and there's essentially no power difference. The main thing I noticed in those videos was the higher octane fuel produced more consistent runs, which supports @GTIfan99's experience above trying out 93, and it supports my experience with 89.From what we know 2019+ cars have a high-octane learning mode, so they should be adding at least a few degrees of timing on premium.
VanCity did shitty testing that likely wouldn't have triggered the high ron learning. He refused to acknowledge that he may have presented poor data and never re-tested. We would need a Simos19 FR to know for sure but I really doubt they took it out post-18.10.I don't know if that's the same on the mk8. A few people have dyno'ed these engines on 87 vs. 93 and there's essentially no power difference. The main thing I noticed in those videos was the higher octane fuel produced more consistent runs, which supports @GTIfan99's experience above trying out 93, and it supports my experience with 89.
Obviously higher octane is less likely to result in knock and timing pull when IAT's go up. But, there is a limit to this because the ECU uses IAT timing tables that will automatically pull some timing advance when IAT's go up anyways as a precaution. But it's controlled and predictable. Conversely, a single knock event usually results in -3* of sudden timing pull that lasts for several hundred RPM. That's a noticeable power suck. MOAR OCTANE PLZ.
He's not the only one that's done a dyno test, and he did the same test on another vehicle (Audi something?) with the same results.VanCity did shitty testing that likely wouldn't have triggered the high ron learning. He refused to acknowledge that he may have presented poor data and never re-tested. We would need a Simos19 FR to know for sure but I really doubt they took it out post-18.10.
