OK have done the testing, some VERY :eyebulge: interesting results. I am now having second thoughts whether any remap really improves greatly on what is otherwise an already fantastic car...
Setup:
Stock logs, acceleration, bluefin install, redo logs then redo acceleration.
7 degrees C ambient temp. :thumbsup:
Contis with 3000+Kms, 38psi all round at 12 degrees C.
Vortex 98 fuel.
Car warmed up with more than 30 mins driving.
Concrete road at Funny's "secret test location".
Surface dry, possibly a bit dusty.
Manual mode, switch to 2nd gear once running, brake/roll until RPM is at 1000, keep throttle steady to maintain RPM at 1000 then WOT for 2 DSG gear changes.
Roll/brake, drive back to original start point to cool intercooler then run next log.
Number of WOT/LC runs over 20!
Blocks measured 2 & 20, 31 & 34, 115 & 230. (only did 122 after Bluefin, forgot to do it at stock for comparison, but then again it was 1am in the morning...). Approx 6-7 datapoints per second.
Time to log - approx 2 hours
Bluefin upload time - 10 mins
Wife - very unhappy that it occured on a Friday night... :frown:
Ok now for the results.
(this has taken ALL day to chart so i'm not going to make it look any nicer. Please ignore "Time" values in graphs as this was the only way i could get graphs from 2 blocks to align together correctly. Also ignore the load %age as % is the label that is used in VAGCOM. I know it's obviously not a %age but have put it in there anyways...)
Idle is completely unchanged for both as expected.
RPM around 800, Fuel rail pressure 50bar, intake air 2.8g/s, no CFs, A/F ratio at 1
Stock maps vs Bluefin maps
Note the 15psi peak and a hold around 11psi before dropping down to the gear change.
Now have an almost 19psi peak with kind-of-a hold at 15psi and dropping to 10psi. Looks like the whole curve got shifted up by 5psi.
Air mass peak close to 180g/s.
Bluefin makes the turbo suck in more at at a 200g/s peak.
Stock and Bluefin Fuel rail pressure identical. I guess that is probably the limit of the fuel system (don't know if it will be the pumps or injectors, me=noob:wink: )
Drops to 0.9 for the first half of the gear, then to just below 0.75 for the rest of the gear.
1.00=14.7:1
0.90=13.23:1
0.85=12.5:1
0.80=11.76:1
0.75=11.03:1
0.70=10.29:1
Curiously a bit leaner with Bluefin in the second half of the gear.
Continued in part 2...
Setup:
Vortex 98 fuel.
1.00=14.7:1
0.90=13.23:1
0.85=12.5:1
0.80=11.76:1
0.75=11.03:1
0.70=10.29:1
