Epic_Sandwich
I Drive a Sedan
- Northern Colorado
No boost leak, my situation is very similar to what I believe you experienced just to a lesser extent. I'm running the DM Stage2+ BETA3 map and only seeing a max of 15-16psi in lower gears and on the highway around 80mph in 5th or 6th I can touch 20psi. I was under the impression I should be seeing 22-24psi.
My car feels pathetically slow in 1-3rd gears because I'm lucky to see 12-14psi, it's like stock nearly.
Boost leak tested multiple times, zero leaks. Replaced DV, added GFB DV+, nothing.
I know I need to log but I have no vagcom. I know I know I should order one. It's on the list.
