wireb
Just a noob with a welder
- Rochester, MN
#1) I noticed mention of the SAT tuner early on, is this needed to interface with CAN? Like I said, Sat tuner is gone, but wiring is still there. Where can I hit the Can lines?
#2) I use Roadrunner (Riderunner now) as the front end in the car, I'd probably be best off using keyboard emulation to control the FE. I saw mention of using a Serial to USB converter in the first few pages, is this possible? I believe the carpc has a serial port but I'd rather not run another line down the car. I'd rather go from the CAN interface to a usb hub behind my monitor.
#3) I assume I can get the left side of the steering controls working right away. In order to have the right side controls useable I figure the CAN interface would have to appear as the radio so it can display an audio menu in the MFD. Without that the right side buttons would just flip the MFD around.
#4 Is the kit, or at least the board still available? I'm pretty good at soldering but I'm half retarded when it comes to anything programming/software related. So expect alot of questions if I get my hands on one
#1 There is a connector under the passenger seat that has the can lines in it. I can look it up in my service manual when I get home. Guessing your monitor is where the head unit should go. If so you may want to tap the old head unit connection to get to the can bus. (again I can look in my service manual when I get home)
What year is your car and did you have a amp under the drivers seat? (Wiring diagrams are different between the options and years)
#2 2 options use a USB to serial adapter (as pointed out above) or use a USB to Parallel adapter. The main difference would be the interface to the software. I have updated the logic for use with PPjoy so that the steering wheel buttons just show up as joystick buttons in windows. Someone else found software to map the joystick buttons to keyboard buttons to control centrfuse (can anyone link to that chunk of code for future referance???)
Down side to the parallel port option is that is all it will ever be able to do. If we get custom pages working you will need the serial port version so you can send the adapter text you want to display on screen.
Down side to serial is more software is needed on the PC to interface it to the software your using. I have all the hardware and interface documentation so if you can find someone that knows how to write plug ins for your software I can help them get it working. (and possibly do some testing on my end)
#3 All buttons work right out of the box. The adapter just says "button x was presses" it has no idea what page or screen is displayed at the time. Without the factory head unit I think the "Audio" page will be gone. (nothing in the ring to display it) Currently a few of us are trying to figure out how to display a custom page but not quite there yet.
#4 Yea the last run was kits. (search back quite a few posts.) I had 3 options:
1.) just a raw card
2.) raw card + programed micro
3.) raw card + full set of parts
The minimum order for raw cards is 6 pieces. So if you can find 5 other people who want one I can place another order. As for the rest of the parts there are no minimums. But if you are outside of the US it may be cheaper to order them locally vs paying the import duties on the full package.
I have a set of build instructions in the zip file on this page
http://www.wire2wire.org/Can_sniffer/Can_sniffer.html
(scroll down to the bottom of the page)
